Luxurious V12 Grunt
Luxurious V12 Grunt
With over a decade of experience and knowledge around restoring these British legends, E-Type UK is perfectly positioned to provide you with your dream E-type. It takes a great deal of expertise to restore a concours worthy classic and unfortunately not everyone has the level of skill required. This Series 3 owner experienced this fact first hand, having handed over his pride and joy V12 E-type to a body shop for an exterior repair and respray. It quickly became clear to the owner that the commissioned party lacked the skill needed to restore the car to its former glory.
After pulling the car from its ongoing process, the client made the decision to commission E-Type UK to start again and fully restore the E-type, finishing this original UK 2+2 V12 to a high performance yet reliable specification, allowing the owner to tour his classic in comfort and style.
starting a new
The difficulty of picking up a semi-started project is finding a sensible starting point. Since this V12 example had already had its paint removed, some repairs and paint preparation started, the team took into consideration the client's end goal and it only made sense to start a new! The E-type was fully stripped with all parts and components catalogued and stored, and the shell was media blasted to ensure no repairs or corrosion had been missed by the last restorer, this highlighted the following required areas:
- O/S rear wing
- Floor plan
- Inner and outer sills
- Kick panels
- Lower door skins
- Jacking points
The team start with the removal of these damaged areas and start installing the new required panels. Alongside this work, the team also make local repairs to the inner wheel arches, boot floor and inner and outer bowls.
A new coat
Working off a complete and solid base, the shell is given to our paintwork team. An integral phase of the E-types restoration, the paint preparation process is where the team ensure exceptional lines, gaps and surface for the paint to be applied to. Once filled and primed the shell is ready for that all-important step - paint application!
- A minimum of 9 litres of Opalescent Gunmetal 2-PAC paint is applied
- Subjected to numerous coats of solid and high-quality clear coat, the E-type's bodywork is complete!
- Now to be flat and polished before moving to the workshop for rebuild.
